Is there a way to split the monitor into sections with Nvidia drivers?
RussianSensation
19,458
765
Hi. I was wondering if there is a way to create 2 "virtual" monitors (ie. Twin view without having 2 monitors for example) with only 1 monitor by splitting the screen into say 2 parts and fixing them (so I can view word on the left side and excel on the right side on 1 monitor but not have to manually adjust it every time).
Is there a way to create 3, 4 separate areas? I remember reading that something like this was possible with Nvidia drivers.
Any help is appreciated.
xtknight
12,974
What about going into the nView desktop options thing (same place where you can make keystone adjustments)? Sorry, can't remember the exact name since I'm not in Windows. Basically it hooks into the shell and allows tons of UI changes. I believe the split screen is in there. I think it just creates guidelines upon the current window station.
http://www.nvidia.com/object/feature_nview.html
