Is there a way to rip the sound file on a DVD into a wave or mp3 file?
eflat
2,109
One of my favorite Elton John performances is on a DVD filmed and recorded in Turkey. I want to be able to play the disk in my car cd or mp3 player without the video..
Anyone know how to do this?
PurdueRy
13,837
4
Many ways however here are the two I do most often
1. You can use video conversion software to strip the sound from a video file.
2. (and more common) Most sound cards have a "stereo mix" or a "what you hear" recording option. If you select this, any sound that comes from your computer will be recorded. Use a free program like Audacity.
3. If your sound card doesn't have a "what you hear" or "stereo mix" option then it probably has a line or mic in. You can use a look cable to connect output to input. Using this method you must make sure your software downmixes the audio to stereo or you'll only get the L and R channels out of the 5.1 track.
