Is there a way to make the sound from Cable not suck?
Anubis
78,712
427
tbqhwy.com
now that i have better stuff its really starting to annoy me how crappy the sound is on most Cable channels.
I have TWC
seems everything distorts and crackles even at moderate volumes on channels like HBO and such. its not the speakers or anything else. BluRays can be played at deafening levels perfectly fine with no issues
besides changeing to another provider (Satellite) can anything be done?
Scotteq
5,276
I have TWC
How are you getting the sound from your cable box to your stereo? That's where I would start investigating: Bad connector on the cable box or bad interconnect would be my first guesses. Swap out wires/types and see if the problem moves or goes away.
purbeast0
53,039
5,920
who is your provider? i've had no issues with fios using just an hdmi cable to my avr.
Anubis
78,712
427
tbqhwy.com
im on TWC - Time warner
coax into cable box, HDMI to receiver -> HDMI to TV
never had any video issues just audio
i have some newer cables coming from monoprice as the one i have is prob anchient- standard COAX cable
purbeast0
53,039
5,920
oh duh you did say TWC in the op my bad.
wonder if the cables you have in wall are just old or something maybe? unless twc's quality is just kinda whack?
Anubis
78,712
427
tbqhwy.com
well pulling from a different outlet seems to have helped some, rest of it is prob the feed. the cable comes into the basement and this is all the way on the 3rd floor. not sure how many times its split below.
time to drill some more holes in the wall
Scotteq
5,276
Lots of splits in the house??? Then have you considered using a drop amp? Your data modem probably won't like it, but mine made a nice difference for everything else. I run one splitter for the modem, then to the amp:
mmntech
17,501
12
Digital or analogue cable? I'm assuming the latter. If that's the case wiring should affect it. With digital you either get a signal or you don't.
bigboxes
40,381
12,240
I'd have TWC come out and adjust the line levels first and then ad the inline amp if necessary.
mmntech
17,501
12
isnt it all dig now?
For the most part. However, some people still have legacy analogue cable. I did miss the OP mention having a cable box so this means he does have digital.
I suppose it could be the cable. You can get digital noise. It certainly wouldn't hurt to check but I'm not sure this is the problem. I'm more inclined to say it's a problem with the box itself, or a headend issue. How many cable boxes do you have? If you've got more than one, do they all do this?
Anubis
78,712
427
tbqhwy.com
TBH im not sure it happens on the other Cblbox/TV, its only hooked up to a soundbar but i can prob check. IIRC i have noticed it on certian movies on HBO or whatever. Cbl box is a newer Samsung one upstairs. the other one is an older SA one
i noticed it again last night when watching Game of Thrones. its almost always the highend that breaks up and pops. getting kinda annoying
vshah
19,003
24
have you disabled all the audio compression settings etc. in your cable box?
Anubis
78,712
427
tbqhwy.com
there re no audio compression settings in my cable box.
seems to be channel dependent
cinimax is horrid
HBO less bad
you can see it in the PQ difference as well. one def pixelates more vs the other at times.
guess ill give a call into TW see if that can do anything
poofyhairguy
14,612
318
One trick a friend did is order 3D content (I think ESPN 3d) for a month. They had to upgrade his box to one that sucks way less for the 3D, but then didn't downgrade the box when the month was up.
He certainly thought it was worth the 12 bucks or whatever.
