Is there a way to make my headphones wireless?
JTKTR
172
I have a really nice pair of shures and I want to be able use them wirelessly with my computer. Is there anywhere I can buy some sort of receiver to hook up to my computer for wireless audio?
vbuggy
1,610
Buy a PMP and walk around with that instead.
You're probably using mobo audio, right? All the more reason to do so.
simonizor
1,312
This. If you're just listening to music, it would more than likely be much more cost effective to just get a good MP3 player.
If you're trying to game, I'm not sure that there really is a good solution to this problem. As others have said, good wireless transmitters are expensive. So unless you want to deal with a long cable, there aren't really any other options.
JTKTR
172
Its primarily for videos etc to avoid waking my roommate. Not using onboard audio (but I imagine that doesn't matter when its being sent wirelessly it will be of a lesser quality no matter what). But the wireless receiver above looks pretty nice. Has anyone used it or can verify its quality?
sdifox
99,420
17,570
so what is wrong with a long cable?
Murloc
5,382
65
a long cable is better and since you're stationary it's not a problem.
you'd be taking less risks too (what if you spend 100$ on something that sucks?).
JTKTR
172
right i understand. Just seems super inconvenient. If only there was a decent wireless receiver.
JTKTR
172
I had sennheisers for awhile but I couldn't lie on my side without distorting the sound in the compressed ear. Their great headphones, don't get me wrong, just sitting up while watching a 2 hour movie got tiresome.
I sound really picky in this thread... :p
sdifox
99,420
17,570
Cheapest solution is in fact ear plugs for room-mate.
watching movie lying down... what are you 12?
JTKTR
172
hahaha. yes. I am 12 :p ear plugs for roommate. Maybe ill slip them in while hes sleeping. Couldnt hurt to try...
