Is there a way to hack IM conversations?
JS80
I was IMing with someone from HR and she calls me to end the conversation stating that IT can read all our IMs. I insisted that you cannot hack IM conversations...
The only way I can think of where IT can read IMs is if you're using Trillian type software which records all convos or if they connect to your computer via the network (like a Trojan Horse). Can someone explain the latter way and if it is possible for IT to "see" your desktop without your knowledge?
Thanks,
JS
there are software available that keeps tabs on every click being pressed by the keyboard. it is all recorded and kept under tabs.
i'm sure there is
and if they have it set up properly they can remote into your desktop and you won't notice a thing
so yeah, they could read your ims
If they're running keyloggers or monitoring your system in any way, they don't actually have to hack anything. They'll just have everything available to peruse at their leisure.
The important thing is to just make sure you don't ever say anything that could get you in trouble on a work computer.
It's easy to do... if you know what servers the traffic is being sent to, you can simply log everything that gets sent to or from those servers. Also, yes, there is plenty of software out there that can be used to remotely view your desktop. You should always assume that anything you do at work is being watched.
You don't know what you're talking about. You don't need to 'hack' IM. All you need to do is log all the IM packets (which i'm almost positive aren't encrypted), something very easily done.
One word:
Ethereal....
Do it all the time.....use GAIM & at least encrypt your conversations.....(with other GAIM users....)
Stop chatting on company time and get back to work.
Next thing will be a thread about how someone got fired because they were goofing off on the company computer. :disgust:
As stated, monitoring your IMs or anything else is trivial if the IT staff is remotely competent.
My senior design project is a network monitor. It's main purpose is to track bad traffic (viral and other attacks), but one of the requirements is it works with IM data, email data, track usernames, and a bunch of other types of data/privacy issue stuff so yes it's possible to keep tabs on it when your sending the data through a network someone else controls.
Thanks,
JS
There are several pieces of software out there for monitoring purposes that allow IT folks to watch what you're doing on your monitor just like you would. You can also sniff packets and watch the conversation in real-time.
It is entirely possible for them to be "hacking" your IM conversations, but it sounds like you're just another young'un who doesn't know what he's talking about. You're on the right track by asking questions, though.
