It won't do anything though unless you have a card that will support it.
Are you sure it doesn't work? All it does is adjusts the card's brightness, gamma and contrast levels to specific amount. The slider might not be there but it should still work.
Try using Riva Tuner instead as nVidia might have changed the registry entry in the newest drivers. Like I said before I'd be surprised if it didn't work.
