I have a relay/temp sensor controller that plugs into my enviromental control server. Currently it is the only device so my program just tries the first ttyACM and if it fails it tries the next until it can connect. I plan to add another device so this method wont work anymore and will actually cause issues if I leave it that way. So I would like to be able to just set the TTY in the device's config file and have that device always appear as that TTY when it's plugged in. I know the order will always stick as long as they are all plugged in, but if one is not plugged in or fails then the rest will shift.
This is a box that will always have various devices added to it over time as I add more home automation/monitoring stuff, so I want a solid way of managing them. In dmesg to me it seems devices give enough info that would allow them to be distinguished even if I did happen to plug two idential ones:
usb 6-2: new full speed USB device using uhci_hcd and address 3
usb 6-2: New USB device found, idVendor=2341, idProduct=0043
usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=220
usb 6-2: Manufacturer: Arduino (www.arduino.cc)
usb 6-2: SerialNumber: 74934303030351C04081
usb 6-2: configuration #1 chosen from 1 choice
cdc_acm 6-2:1.0: ttyACM1: USB ACM device
So is this possible in any way to force a specific device to a specific TTY?
