- Apr 28, 2004
- 311
- 2
- 81
If you're using MSI Afterburner, detach the graph monitor and place it on the second monitor. It updates in background if I recall correctly.
No, it doesn't work with some games, and some games it can work with can break with AA modes, or using AA and/or shader injectors. You'll get nothing at all, or 0 FPS reported. FRAPS will report FPS, but AFAIK, it only shows on the primary monitor.fps worked for me on the Android phone - may need to enable it scroll down to bottom of the list under the Monitoring Tab
or maybe that setting is only for actual MSI cards?
I don't think the graph portion of MSI Afterburner nor the mobile app will show me the FPS count of a game I am playing. Unless this is a setting I don't know about?
