Is there a way to combine two audio source into one audio in port?
Xellos2099
2,277
13
Long story short, I been hooking up my ps2 to my tc tuner card and use the blue audio in port to get sound. However, I just purchased a 360 over christmas and plan to use a vga cable for the monitor, but I need to do something about the audio as well. I decided to go same route and use the blue audio in port on my computer. The question is, there is something cheap I can buy that would combine both audio source into the blue audio in port? In short, is there a way to combine t 3.5mm source into one.
Actually, would this work? http://www.dealextreme.com/details.dx/sku.16814
Or would it only work as two output and not in 2 input to one source?
krotchy
1,942
That would work, but it definitely leaves the potential for damaging one of the components.
Xellos2099
2,277
13
Hmmm, it sound dangerous. Is there somethign a little bit safer. Anyway, as of now, I plugged my ps2 audio to one of my monitor that got weak speaker, it work, just not as good as my 5.1 speaker.
krotchy
1,942
My friend has a mechanical switch for his SPDIF optical thing. I have no idea where he bought it, but I am sure you can find something cheap like that or something more expensive like an electronic switch.
thomsbrain
18,148
I assume you are talking about analog audio here.
If you want to avoid any possibility of messing anything up, you can buy a cheap composite A/V input switcher. Monoprice.com would probably be the cheapest and most reliable option for something like that.
But I think just using a simple Y-splitter would *probably* be fine as long as you only turn on one component at a time so you don't overload the input.
