Originally posted by: antillean
You charge batteries by running a current through them backwards. I wasn't sure how the amps would work, whether you'd have to limit or no. I guess it wouldn't work
The battery puts out 1.4v. The charger apparently requires a higher voltage to detect the battery. Why they would design it like that is beyond me. I have to buy a trickle charger in order to use my fast charger-- WTF!?!?
I think that once a NiMH cell drops to around .9V under load, it's considered "dead." Much less than that and I think you'd be risking damage.
It's possible that one cell in the pack is dead, and so reduces the voltage of all the cells in series. I've had some cheap Powerizer brand AA's from Thomas Distributing recently, and they died after less than 100 charge cycles, as in, they hold a voltage of about 1.2V, but then after only about a minute of a 0.1 amp load, they drop down to somewhere below 0.1V. Chinese crap, it seems. Meanwhile, some Japanese Sanyo-brand AA's that I bought years ago on clearance at Walmart are still working perfectly.
I'm looking forward to buying some Eneloop AA's, also made by Sanyo. They're NiMH's that are supposed to maintain 85% of their charge after a full year in storage.
And I see by the post before mine that our local expert has arrived.
