Is there a way to append a flash embed so that it skips to a specific frame?
Syringer
19,333
I have a main flash banner for my site along with 10 different pages..and I want to keep the same toolbar but have the images change on each page. Right now I just exported 10 different swfs with a different image on each of them, but was wondering if there was a way to just have one swf file and in the embedding command to skip to a specific frame within the swf?
GaryJohnson
940
If I recall correctly, you can add a query string (like a HTTP GET) to the end of the URL for the SWF like so:
<EMBED src="myflashmovie.swf?skiptoframe=5">
That ends up as the value of: _root.skiptoframe
wwswimming
Banned
Jan 21, 2006
3,695
the command "gotoandplay(5)" comes to mind, that would be for skipping
to frame 5. i would have to get out some old homework.
i don't know how to do it outside the Flash programming environment.
there's probably an exact tutorial for this at
http://www.gotoandlearn.com/
DaveSimmons
40,730
670
Like GaryJohnson said you can pass variable values to a SWF using CGI style in the URL or a
< param name='flashvars' value='x=val1&y=val2&z=val3...' > tag in the < object > .
In your ActionScript for the first frame you look for the variable and if found do a gotoandstop or gotoandplay.
Syringer
19,333
Hmm I'm confused..so my flash embed would say:
<param name="movie" value="header.swf?skiptoframe=300" />
And in my actual .swf it would say: gotoAndStop(_root.skiptoframe);
Or how would I modify the embed src?
Edit: Awesome, it worked! Thanks.
