Is there a specific guide for OCing an IP35 PRO + e8400?
Burrich
70
Originally posted by: piotrgurin
It keeps freezing with double orthos after a few mins.
Are you running two instances of Orthos? Are you actually hard-locking (where you have to reset your PC manually)?
piotrgurin
343
Yep to test i would run two instances of Orthos SP2004 BLEND (1 for each CPU)
The mouse freezes and the keyboard locks us and i hard rest with the case reset button.
Burrich
70
I downloaded Orthos last week and just one instance would have two threads that would test both cores. Is this not the case with yours?
piotrgurin
343
I guess it depends on how much you want to stress ?
With one instances i'm getting 100% in one core and 50% in another,
With two instances i'm getting 100% in both cores.
What is the standard people use to judge with?
Anubis
78,712
427
tbqhwy.com
what are your CPU Ram, and northbridge voltages,
something prob needs some tweaking,
also what is your OC
piotrgurin
343
It seems like my comp is more likely to freeze when i'm opening up cpuzs and speed fan. I'll keep trying and see if i can get a screen shot b4 it freezes again.
Tweakin
2,532
From you screen shot it looks as though you are running two instances on core 1. I also noticed that your memory is getting up there, what type of memory are you running?
Tweakin
2,532
Your right that screen shot was running two instances, but look it went 8 hours no problem!
Yes you are...but on the same core. One should be on cpu0 and the other on cpu1
Anubis
78,712
427
tbqhwy.com
yes running 2 on 1 core may be whats killing you yhowever 8 hours like that doesnt seem to bad, personally if you cant even run 1 at a mild OC like 3.6 for 12 hours i would start upping voltsgaes, it looks like you have the CPU at 1.35 with a large vdroop, a slight notch up here might work,
upping ram to 2.0-2.2 may help, i also had to up the voltage on my northbridge by .2 to get 100% stable at 9x440
piotrgurin
343
Alright what is going on here.... I can run dual orthos day and night on all the different setting no problem.
But as soon as i open up all my little programs, speedfan, cpuz, etc the comp freezes! what gives?!?
M1A
1,214
I had some of the same not sure yet what was the problem but mine is ok now. Maybe others know more.
piotrgurin
343
hmm,, should i just keep ocing without those progs?
Binky
4
On my IP35 Pro I can recreate a lockup at will by opening CPU-Z and uGuru. It may have been speedfan and CPU-Z...don't remember. This really isn't an OC problem, it's just one of the quirks of this MB. I do love the MB though, except for the poor E8400 support.
