Is there a resolution size between 800x600 and 1024x768?
alm99
4,560
I had installed a game with messed up my display settings. I uninstalled and reinstalled drivers, but now my display is either too big(800x600) or too small(1024x768). The text on and thumbnails on my desktop were a little larger than what they are now at 1024x768, but I can't find the right resolution.
SchmoeZA
Dont know what your problem is, but to answer your question: the res between 800x600 and 1024x768 is 848x480, although it is a bit of an odd aspect ratio
Abhi
4,548
Put your resolution at 1024 X 768 and use the large fonts and icons option ....
BFG10K
22,709
3,003
There's a 972 x Y (I forget what it is exactly) but it might not be available without a bit of tweaking on your part.
Pete
4,953
Do you need to just ensure you're using your previous refresh rates, or resize your monitor's image?
