Is there a place that sells those Antec rubber fan screws/fan mounts?
0roo0roo
64,795
84
many antec/chieftec cases have those plastic fan mounts, so they are held with little plastic feet that go throughsquare holes. i've seen rubber fan mounts/screws that attach through such square holes on other antec cases, is it possible to buy these?
Zepper
18,998
SVC.com. oh, you mean the fan cage. You can get them direct from Antec, Chieftec, etc. as replacement parts. If you want plastic, push-lock fan fasteners, cyberguys.com has 'em.
.bh.
RalfHutter
3,202
These are what the Antec versions are based on. You can also buy them from McMaster-Carr for half the price that SiliconAcoustics charges, but you have to buy them in packs of 20. Search the SilentPCReview forums for "5801K6" and you'll find the details on how to order them from McMaster.
0roo0roo
64,795
84
yea, thats pretty much what i'm talking about, do those fit square holes of some of the antec towers that ussually use tooless fan holding bracket things? and thanks for the link:)
RalfHutter
3,202
They'll fit through any shape of hole, as long as the hole itself is large enough to get the isolator through. (Here's a picture of them fitting through a hex-shaped hole) Those square holes in the Antec/Chieftec cases don't line up with the hole pattern on an 80mm fan though
MDE
13,199
Originally posted by: RalfHutter
Originally posted by: 0roo0roo yea, thats pretty much what i'm talking about, do those fit square holes of some of the antec towers that ussually use tooless fan holding bracket things? and thanks for the link:)
Nothing a drill\Dremel can't fix :).
