Is there a noticeable difference between these two Minis?
MotionMan
Mini 1:
2GHz Core 2 Duo/4GB 1067 DDR3
Mini 2:
1.83GHz Core 2 Duo/4GB 677 DDR2
Is there a noticeable speed difference between these two Minis? Would any speed differenced be noticeably "enhanced" upgrading from SL to Lion?
Thanks.
MotionMan
#1 would be faster due to the faster bus speed more than the CPU speed. First thing I would do is bump it to 8GB for cheap.
Speed is a relative term, it really depends on what you want to do. I would upgrade the ram before throwing Lion on it.
If I have to crack open No. 1 and pay for RAM, my question will become moot.
MotionMan
MotionMan
You don't *have* to pay for ram, they both have 4GB. That's enough to do stuff with. If you want a better experience and faster response, then go with 8GB.
Obviously, that is true, but it does not answer my question.
Nor does suggesting I add more RAM.
MotionMan
to also not answer your question, I've personally decided not to upgrade to Lion on my (ancient) Core 2 Duo MacBook w/ DDR2 RAM. It's unfortunately limited to just 3GB and I don't think I'll benefit much from Lion.
I haven't seen any benchmarks of Lion on 3-4 year old Macs, so it's hard to answer your question directly. At this stage, I wouldn't buy any computer that uses DDR2 memory.
Seriously, as they are currently configured, would there be a noticeable difference?
MotionMan
Almost certainly not outside of synthetics. What are the GPUs in each? That might make a difference for Flash and HD video playback that will be noticeable.
Unless you are comparing Core 2 to Sandy Bridge, or platter to SSD, you aren't going to notice a whole lot of difference in a few hundred MHz. Comparing the 1.4GHz Core 2 in my Air to the 2.4 in my friend's Pro (both with SSDs) you can definitely see a speed difference, his is more powerful than mine, but between what you listed? Fuhgedaboutit
Probably not. I don't think the differences between DDR2 and DDR3 are that noticeable at those speeds. And the CPUs are close enough in speed that they probably won't make a difference either.
I upgraded my 2.26 GHz Core 2 Duo MacBook Pro which had 2 GB DDR3 1067 MHz RAM. With 2 GB RAM it felt about the same in Lion as it did in Snow Leopard. Both felt somewhat lethargic, and bringing it to 4 GB RAM didn't help much (since I wasn't a heavy multitasker). What really sped it up was putting in an SSD. With the SSD, it felt like a brand new machine, even with just 2 GB RAM.
I really don't think the RAM is the main limiting factor here, even with DDR2.
I'd go with #1. It has a Geforce 9400M GPU versus the second one which uses the seriously outdated Intel GMA950.
