is there a HTPC case out there that supports liquid cooling?
BirdDad
1,131
I want to place a liquid cooler in my next HTPC but have yet to find a case that it would work in.
Any one know of one?
Charlie98
6,298
64
If you are looking for a traditional HTPC (horizontal) case, probably not. Have you considered a cube? It seems like all the cube cases have WC support....
aigomorla
21,077
3,578
I need a case that can fit in a 7 1/2" shelf.
not possible.
The 120mm fan itself is 4.72 inches... which is required for most AIO's / water kits.
Fractal Node 304 has wc support on the rear fan mount.
i already looked it up for you guys.. and it wont fit...
its 9.4 inches.... on both the 304 and CM130.
there is just no way he can get what he wants at 7.5inches.
velis
600
14
I built a WC system in a Silverstone GD05. Mounted the rads on the sides.
This is how it looks (sans the 3.5 bays & res - sorry, took the image from my ekwb thinkcell project):
The entire thing is ~16cm high (6.3")
SithSolo1
7,740
11
BirdDad
1,131
not possible.
I got it going, required modding and no place for optical drive but it works
Blain
You can jam a case into a small space, but even if it's "water cooled", there still needs to be plenty of ventilation area for the hot air to be dumped off.
"Water" is only the medium for transferring heat from a water block to a radiator.
BirdDad
1,131
I can take some pics. I will take some a little later and post them, it really isn't anything spectacular, I had to do away with the optical drive in order for the cooling lines to fit.
aigomorla
21,077
3,578
lol if u said modding is accepted, i could of been more help.
I assumed you wanted a pure plug and play application case.
And yes i would like to see this low profile HTPC case u selected and how you modded it.
BirdDad
1,131
it is not a low profile case, I never claimed it was. Any way I have pictures. I do not know how to post them, the FAQ says On this page, below the message box, you will find a button labelled 'Manage Attachments'. Clicking this button will open a new window for uploading attachments. You can upload an attachment either from your computer or from another URL by using the appropriate box on this page. Alternatively you can click the Attachment Icon to open this page.
There is no Manage Attachments button on mine.
velis
600
14
If you share those pictures publicly on G+ or Facebook, you can link them directly using img tag.
Shame Anandtech forums don't provide a nice graphical interface for special formatting / links.
