Thank you. I just quick-read that thread. The last post (extensive) was obviously knowledgeable. I already ran Easy Transfer on this machine (still XP running on HD), saving the file to an external USB HD. I presume I won't have difficulties restoring from that. After all, both OS's are 32 bit, what can go wrong? That said I think it's prudent to image the clean install of Win7 as you suggest. I don't think my Ghost 2003 will do it, it seems to usually/often/? have problems saving to an external USB HD (doesn't see it when picking a save location, but sees it fine when picking a save-from location, don't ask me why!). I may just have to install Acronis True Image (the external HD is Western Digital) and use that, it will be my first use of it, so... 😕I would only hesitate to use it because the directory structure is different when comparing the 2 OS's. That being said as long as you have a backup of the clean Win 7 install I would try it.
This link may be worth looking at also. http://answers.microsoft.com/en-us/...to-win-7/79f2befc-9a67-4e4b-9083-aba94ea05d6e
We used the tool built into XP when we upgraded 200+ machines at work (from win 98) and had very few issues.
I'm a bit late to the party, but I would say the answer is that there is no downside. I have upgraded a few machines over the years in this manner and it has worked extremely well.I'm installing an SSD on this XP laptop and installing Win7 32 bit, a clean install. Is there a downside to running MS's Easy Transfer to save and then restore settings, accounts etc.?
Well, on the face of it it does look extremely easy, at least the path I took with saving the file. I haven't installed the SSD and Windows 7 yet and tried to restore from the file, that very likely very shortly.Just my personal experience but I am extremely leary of any claim by MS that something is easy. but thats just me though.
Note that the GPU driver isn't even loaded at that stage though. His system is failing on a simple VGA screen. That still points to a hardware failure in my book.I cant imagine the laptop is overheating that soon into the boot process unless the heatsink on the GPU literally has detached from the GPU and any load at all is causing a massive temp spike. Sounds more like a driver issue where the GPU is locking up as soon as the basic onboard video hands control over to the discrete driver right about when the windows splash screen pops up.
If you can get to the desktop, I would uninstall the GPU driver completely and reboot, then do a clean GPU driver reinstall without the docking station. Installing drivers while in a docking station is always a crapshoot, especially on those T60s and X60s.
Back on the original topic, I use the windows easy transfer tool to go from XP to 7 systems all the time at work, even between bitness. It works great, and only carries over superficial profile settings that are valid between both systems (power settings, start menu preferences, folder settings, etc). Anything that would be considered heavy lifting is beyond the scope of the tool anyway specifically so it can't fudge it up.
I rarely boot from an actually cold state, it's almost always a restart, so the machine's quite warmed up. It may be a stretch to suspect an overheating GPU because the symptom I'm getting is that hang at the splash screen. However, yesterday I couldn't execute any Youtube videos, probably unrelated but who knows. I subsequently removed the HD and replaced with SSD, so...
Yes, maybe a driver issue, but a similar problem carrying over to new SSD and Windows 7 install has me suspicious that it's hardware. Anyway, last few times the machine has rebooted (in a warmed up condition, too), no hang.
Nice to hear about the Easy Transfer, I am still a ways away from restoring. Right now running Lenovo and Windows updates. ATM, I'm installing MSE and it's scanning the system. Obviously there should be nothing for it to find, but I'm letting it do its thing. I will obviously be doing this stuff well into tomorrow. I'm a ways from even installing any programs...
Question: Should I have a look at and install any "optional updates" when running Windows Update? I haven't bothered looking at them yet...
Thanks for the help!
Thanks, I just noticed this post and I'll follow up by installing GPUZ, a free utility I surmise.Easy way to tell if it's a heat issue, install GPUZ and look at the temps. The card shouldn't be locking up/shutting down until at least 100C+
As for Optional Updates, i'd say yes, look through them. Things like improved versions of RDP, .Net updates, language packs (for Ultimate), and general usability stuff tend to get shoved into the Optional category. Unless it's something that's clearly junk like Bing integration, I install them. You can also find driver updates under Optional if the manufacturer decided to supply them via windows update, which is good for NIC drivers and such. On a fresh install usually the only drivers I install manually are NIC (if not supported by the base Windows driver), Chipset, and GPU (if discrete). I let windows update take care of the rest instead of playing around with a dozen manufacturer websites.
Correct. The GMA iGPUs don't provide temperature data since they're part of the Northbridge. But they also draw next to nothing for power, so it seems unlikely it's overheating.I installed GPUZ, the latest version 0.7.8, ran it. I don't see any info about temperatures. Maybe it can't do that with my integrated Intel 950GMA GPU. 😕
