Originally posted by: Ornery
Use
Durabond powder. Use as little or as much as you need, and save the rest for another project. It's VERY strong, yet easy to sand. Spackle is a pain to deal with, because it's hard to spread, drys slowly and is difficult to sand. Not to mention it's more expensive, and dries out in its container if not used within a year or so. Spackle is overall stronger than drywall compound, but not user friendly.
Durabond in residential use is really only suitable for the repair of plaster. It is very hard comparable to bondo when sanding.
If you are repairing nail holes or small defects in drywall lightweight spackle will do and usually can be painted in 30 min. or less.
If you are replacing a piece of drywall you will have to use drywall compound. The premix is the easist as you will not have to mix it. If you only want to use a small portion and not waste the extra material. Use a powered product such as USG easysand. Powdered leightweight can be purchased in estimated dry times. They make 20 min, 60 min, 90 min. If you have a small area, use 20 min, you will be able to do three coats using a fan over an 8 hr. period.
There are basically three types of joint compound
Durabond (very difficult to sand)
All pupose joint compound (medium sanding, shrinkes and cracks more in thick coats)
Leightweight joint compound (easy sanding, used in about all taping of new construction in about the last 10-15 years)
Years ago leightweight was not recommended for bead or applying drywall tape. Improved products have now made this possible though.
