is there a difference between a cat5 cable and a crossover cable???
MiniMe69
290
cat5 is consider regular networking cable...it is cross-wired...crossover cable is categorized as crossover but i think it is straight-through...no wires are crossed.
Viper GTS
38,107
433
Cat 5 refers to the type of cable, crossover refers to the pinout.
A crossover cable routes the send pins to the receive of the other end, & vice versa, eliminating the need for a hub or switch when connecting two devices.
Viper GTS
Doctorweir
1,689
Viper got it...
CAT5 is the specification of the Cable regarding general layout and other requirements.
In addition there is the normal 1:1 cable and the crosslink version. 1:1 only works with hubs and switches between the computers. If you want to connect two network cards directly, you need a crosslink version.
I think at least two pairs of cables are changed on one side compared to the 1:1 cable...
picardal
743
hey guys ...is this what i need???? I kinda want to order from this site so let me know:)
Thx:)
They call the cable--pc to hub--
they also have another cable called pc to pc....
dont know which one to get???
here it is :)
ST4RCUTTER
2,841
picardal,
What do you plan on doing?
If you have a hub get the pc to hub, which is a straight through Cat5 cable.
If you're directly connecting two computers together, as in a proxy server situation, get the computer to computer Cat5, which is most likely a cross-over cable.
yiwonder
1,185
PC to hub is regular cat5 cable, while PC to PC is crossover cable. If you are using a hub, switch, or router, then buy the PC to hub. Or, if you will directly connect a PC to another PC, use the crossover cable (PC to PC).
EDIT: ST4RCUTTER beat me to it.
picardal
743
Ok, wasnt sure which one was the crossover cable:) Thats the one i need!
Thx guys...i hope thats the right one:)
