Is there a conversion between Gross HP and SAE HP
RU482
12,689
I was reading an article about an older (60's era) car and they made a point to mention that the horsepower rating was gross horsepower. Is there any easy conversion to todays (american) method of measuring horsepower of a vehicle? If so, why don't the articles just do the math for us
vi edit
62,484
8,344
I beleive that it really depends upon just how much is lost in the drivetrain and especially in the auto transmission.
I've heard that at the wheels estimates are anywhere from 10%-15% of the "true" HP.
I think that's what you are looking for :eek:
Pacfanweb
13,155
59
Yes, like vi edit said, in the 60's, HP was measured at the flywheel, whereas now it's measured at the rear wheels. I've always heard 20% used as an average loss from flywheel to the ground.
Redneck
386
The difference between gross and SAE (net) HP, is that gross hp tests were run without accesories (A/C, power steering, etc.) and now they are run with all the accesories, which gives a better idea of the performance you will see on the road. Car makers stll use flywheel numbers because lets face it, bigger numbers look better.
