🙂The currently overall best DDR solution for Athlon & Co. is the 7DXR
in terms of performance, features and design. The 7DXR has
- a 3 way power supply (the 8K7A has only a 2-way power supply and is running MUCH hotter)
- a 4-channel CL chip (the 8K7A has only the VIA integrated solution)
- an AGP pro socket with an additional power socket (8K7A nothing)
- DIMM sockets (8k7A only 3)
- 5 fans headers (8K7A only 4)
- Promise Raid controller (the 8K7A has a High Point, that's a matter of taste, but most people prefer a Promise controller)
- high quality impression with blue PCB, golden HS
The 7DXR went slightly higher in both FSB and CPU frequency in our review. That board is now in such a high demand in some countries that some vendors in UK have hundreds of back orders. Unfortunately this board is rather expensive.
The 7DXR and the 8K7A are based on the same chispet the AMD 760. The performance is identical. The 7DXR looks expensive and is expensive, and the 8k7A looks cheap and is cheap. In "actual" life I would say, the 8K7A is as good as the 7DXR, because it's cheaper and obviously you easily get the baord.
