Is there a better place to stream from than hulu?
Tbirdkid
3,758
4
I mean, the quality from hulu isnt that great. Is there a better place to stream thats free? Also, i am trying to use miro, but its not that great either. Any suggestions? I am using windows 7 ultimate if you need to know...
sivart
1,786
Not for free, that is about the best you are going to get.
Are you streaming the highest quality? I found with a 6Mbps connection and wireless I couldn't get the highest quality. I had to go hard wire to get the best quality.
Looks fine until there is fast motion then it jitters some.
Just proof that streaming isn't ready to replace the cable / satellite provider anytime soon.
Tbirdkid
3,758
4
Maybe the wireless connection is what is doing it. I will try it wired to see if i get a difference. I have fios, so i am getting 15 dedicated...
Thanks for the reply!
vshah
19,003
24
with 15mbps you should stream the highest quality no problem. are you having issues with blockiness, or with stuttering. playing HD in flash is very CPU intensive...what processor do you have?
also i've found netflix's HD quality to be better than that of Hulu, but netflix isn't free...
sivart
1,786
Hulu has HD? I thought that went away several months ago. Also, with Netflix, no HD streaming using a PC :(
Tbirdkid
3,758
4
processor is a 3.2 ghz dual core pentium
graphics is a 9800gtx pcie 1gb
4 gigs of ddr2 800
160 gig sata drive...
