I need to connect an older APC ups to the computer is protecting, but don't have the cable, I can't figure out if I can use any old serial cable or if APC uses a different one.
It's not needed, but if you want the automatic shutdown to work you have to have it. My Dad's got an older "dumb" one that's just basically a battery pack.
