- Apr 7, 2003
- 2,021
- 0
- 0
If you're sitting in a room (just a typical room at STP, not a lead-lined room on top of everest or anything :/ ) with one device producing a 40 dB noise, would turning on a second device which produces 30 dB increase the ambient/background noise that you perceive? Consider they're both the same type of noise, too... not a vacuum cleaner and a doorbell.
Just in case my unedumacated question is confusing, here's another example: What if two devices, producing the same type of noise, at the same 20 dB level, are turned on in an otherwise silent room. Would the background noise be greater than 20 dB? If so, by how much?
I'm just trying to figure out what the perceived difference in noise level might be for, say, one 40 dB case exhaust fan vs. four 20 dB fans. I know there's other sources of noise (air gaps in the case, static pressure, etc), but I'm just hoping for info on this specific, idealized sort of situation.
