Originally posted by: mpilchfamily
Cases are as quiet as you make them. It has average 120mm fan in it so there is some noise. But fans are easily replaced.
And adding a fan speed controller is quite simple and can be as cheap as $3 if you get the cheap zalman fan mate or something and just leave it in the case at your preferred setting.
