Is the GTX 970 a 256bit card or not? I bought it because it was 256 bit.
Status
Not open for further replies.
MeldarthX
1,026
That was a long time ago. The way things stand for drivers right now:
Stability
AMD >>> Nvidia
Performance Optimization
Nvidia >>> AMD
I'm so calling BS on that Hurly; shall we look at 700 series from Nvidia and compare it to 7000 and 200 series?
Witcher 3 is a prime example of just how badly Nvidia is screwing anyone that bought older card; *yes they put out drivers that for some have increased; to say it was an oversight BS; again more lies from Nvidia*
tential
7,348
642
121
Seems like the op is extremely out of touch with what performance metrics matter.
Keysplayr
21,209
50
Just look at performance OP. Memory bit width has little to do with performance these days. Otherwise you'd see 512bit GPUs blowing the doors of of 256. That's not what's happening. Focus on performance you want at the resolution you use, or intend to use. You'll be fine. GTX970 is a fantastic GPU.
Rvenger
Elite Member <br> Super Moderator <br> Video Cards
Apr 6, 2004
6,283
For the other members turning this into an AMD vs Nvidia debate. Leave this thread before I start infracting you.
-Rvenger
mindbomb
363
the width of the bus doesn't mean much. There is a melange of things that affect memory bandwidth, and memory bandwidth in itself is only a subset of the things that affect performance. Memory bandwidth is influenced by the frequency of the ram (ie 7ghz gddr5), the width of the bus, the efficiency of the memory controller, and the use of lossy compression can effectively increase bandwidth.
Furthermore, you have examples such as the 256 bit gtx 980 beating cards with larger memory buses (the 780 and 290), as well as the 128 bit gtx 960 holding it's own against the 384 bit 7970 and 256 bit 760.
And the concept of memory bus width exists in CPUs as well, but no one cares at all in that medium. Haswell-e had 256 bit (quad channel) ddr4, and the normal haswell is 128 bit (dual channel) ddr3.
DaveSimmons
40,730
670
The short answer is it's 256-bit until your game uses the bad 0.5 GB.
There is 3.5 GB of good memory that runs at 256-bit speed, 0.5 GB of poison memory that when accessed causes steep performance drops. nvidia drivers will try to keep games from using the poison memory but you may need to manually adjust settings in some future games.
My current card is a GTX 680 and the card before that was a 560ti but I would not buy a 970 unless nvidia ever offers a way to completely disable access to the bad 0.5 GB. But marketing will probably not let them do that since they want to sell it as a 4GB card even though it is not really.
Azix
1,438
67
my understanding was that its never a straight 256bit. Its 225 or something for the first 3.5gb
Keysplayr
21,209
50
Dave, there isn't any 0.5GB of "bad" memory or "poison" memory. The story was overblown. The functionality of the card is excellent. The most volumous public outcry was the fact that Nvidia did not mention any of this on the retail box or literature until it was too late. Aside from that, there were only a few rare manifestations of any slowdowns or hitching in certain games at higher settings and resolutions as any card does when it reaches it's memory limit threshold. It was often a chore to actually get the 970 to use more than 3.5GB of memory and reviewers had a hard time getting them to do it.
Is the 970 a 4K card? Not really. TitanX and 980Ti are just entering that realm. Is it a 1080 or 1440 card? Absolutely. Comfortably.
OP, you can be certian though that you are about to see every instance of 970 using over 3.5GB of memory in the next few posts. Then we can dissect them and see what devils lie in the details.
Anyway, here is some light reading.
http://wccftech.com/nvidia-geforce-gtx-970-memory-issue-fully-explained/
http://techreport.com/review/27724/nvidia-the-geforce-gtx-970-works-exactly-as-intended
http://www.pcper.com/reviews/Graphi...Full-Memory-Structure-and-Limitations-GTX-970
http://www.techspot.com/news/59509-geforce-gtx-970-memory-allocation-issue-explained.html
https://www.youtube.com/watch?v=jPlCIUh_Tp0
https://www.youtube.com/watch?v=v6k55epUBCE
vissarix
297
I have read conflicting information about this, I would appreciate some clarification.
Thanks
its not 256 bit exactly, but is enough to wipe the floor against amd 512bit flagship while having lower power consumption, running cooler and huge overclock capabilities...
You really should have read post 30 in this thread. -Admin DrPizza
Keysplayr
21,209
50
Can we PLEASE leave AMD out of this!!
sigh.. welcome to Anandtech.
xthetenth
1,800
529
If you're going to bring that back into this, at least be right.
It's a good card for the price, but the 256 bit isn't a huge influence. Actually 256 bit is low for the card's power but it effectively has more bandwidth than the width would indicate.
AnandThenMan
3,979
589
This is why you don't want a GTX970
1) Memory interface. The card is not a true 4GB card, the GPU is a harvested die and as a result the memory access pattern is inconsistent, a technical limitation. This can and does cause hitches/stuttering.
2) Driver support. To get around the asymmetrical memory requires driver aware support for games, otherwise the game engine will assume the card has a full 4GB and use it accordingly. When this happens, the last much slower 512MB block will produce frame rate issues.
3) Long term ownership. This ties into driver support, Nvidia has shown that they are not shy about abandoning continued optimizations on older hardware (Kepler) so it is not a stretch to say the same thing will happen with the 970.
The safe play is to just avoid the 970 and get the 980 or the 290X.
Keysplayr
21,209
50
1. Yes, the card is a true 4GB card. The GPU is a harvested die resulting in a GTX970 instead of a 980. The memory pattern is by design, consistency has nothing to do with it as it runs the same all the time. A technical limitation for sure, but one that does not adversely affect gameplay except under extreme circumstances as is true with ANY GPU in existence. I'm sure you ran through all my links and both videos before you posted this.
2. Driver support. The driver isn't really a concern of the end user if it does what it is supposed to do for any GPU. So, number 2 is a larger than normal reach. Kepler is receiving performance improvements through recent drivers. Your point is noted but also exaggerated.
3. Long term ownership potential applies for any graphics card purchase. And why would you equate 3.5GB of full speed memory and 4GB (512MB) could make the difference between short term and long term investment potential? I'd say 6GB would be a worthy jump from any of the 4GB cards would be grounds to declare longevity.
You exaggerate every point you tried to make. I just hope the OP doesn't fall for it.
xthetenth
1,800
529
The 970 will hold value and is cheaper enough than a 980 that it has a better long term support plan in the form of selling it and buying a new card. Depending on how worried you are (I think the internet hate machine having a bunch of them means support will be remembered just fine), it may well be a significant factor to encourage a 290(X), which is a case that's made better by the 290(X) being crazy cheap for the performance. And I don't think the OP is in any danger of buying AMD no matter how compelling.
Melanija
Banned
Jun 12, 2015
4
256bit, but it has 3.5GB of memory, rather than 4gb. it also has less bandwidth as opposed to the advertised one!
Lepton87
2,544
9
He is not exaggerating about the Kepler issues. I had two Titans and I couldn't even enjoy a game(the Witcher 3) I bought at 1440p Those cards cost 1000$ a piece, it is truly unacceptable to leave its users in such a situation. Period. If the cards were 5 years old and we would be at a new node then fine, I'd understand. The cards are still too new and it was very deceiving to give it 6GBs suggesting at least a good longevity only to make those 6GB totally useless even with SLI.
bryanW1995
11,144
32
In short, yes it is 256bit. But not really. nVidia cleverly hid the "not really" part from folks who bought the card during and after release.
To touch on the concerns that gamers have, the GTX970 is 224bit wide (not 256bit) memory bandwith for up to 3.5gb's of the cards memory, not the full 4gb.
That's what got some folks peeved. nVidia was deceptive on how the specced and marketed the card initially. In addition to memory controversy, there was also inaccurate initial ROP specs and perhaps other.
From TechPowerUP
Bro...the OP is trolling us. Come on.
Stability
AMD >>> Nvidia
Nvidia >>> AMD
I know a bunch Kepler owners who would beg to differ with you...NV driver team has almost completely ignored kepler since maxwell came out, other than to "fix" some issues with 970.
^^^ Good advice here. Wait a few weeks and 980 should be cheaper if you prefer NV, 970 just looks to have too many questions surrounding it. It's looking like the new cards coming out from the Red camp will end up benefiting us all, even if not many people actually buy them.
Lepton87
2,544
9
As a Kepler owner and previous owner of two flagship Keplers one of which just got burned due to a leak I agree and that's the reason I still haven't replaced them with the 980Ti. I feel deceived. 6GB was a marketing gimmick not future-proofing. This time I'm going to bet on less RAM and lack of planned obsolescence thus I'm waiting on the FURY. I feel fine with 2560x1440 so 4GB should suffice. I'd feel much better with more RAM tough but I'm not buying from NV. I feel burned.
bryanW1995
11,144
32
Oh come on Keys. NV has a ton of great cards these days, and they have earned their dominant market share...but recommending a 970 to somebody with all the smoke around that card is a disservice. NV was deceptive about the memory and the RoP's, and the card didn't really thrive until it got some serious driver support. What's going to happen when that driver support dries up in 12-18 mos when the next gen comes out? At least tell the OP to hold out for 980 price drops (as I did), there is no reason to recommend 970 to anybody right now unless the price drops through the floor on it (say something like <= r9 290 prices).
bystander36
5,154
132
Have you considered that there is nothing they can do to make them perform much better? The latest games may use techniques that the Kepler architecture is just poor at. Perhaps due to compute usage.
bryanW1995
11,144
32
I'm pretty excited about Fury, but the more I read about this the more I think that 980Ti is just going to be a flat out better card. And if you're buying top end, then you'll be buying again when the next gen comes out...at which point you won't care about driver support. 970 is a different animal b/c it's more mid/high, and many of those type of buyers (like me) might skip a generation or 2. or 3. It's reasonable to expect issues going forward with 970, but those concerns wouldn't bother me so much with a 980 or, especially, 980ti.
That argument doesn't hold water, as for many generations now we've seen AMD cards improve vs their competing NV models on the same games as the cards age.
Keysplayr
21,209
50
Sure thing.
http://wccftech.com/witcher-3-initial-benchmarks/
http://wccftech.com/witcher-3-increase-performance-nvidia-geforce-gpus/
http://www.guru3d.com/articles_pages/the_witcher_3_graphics_performance_review,5.html
http://www.techspot.com/review/1006-the-witcher-3-benchmarks/page4.html
http://www.techpowerup.com/reviews/Performance_Analysis/The_Witcher_3/3.html
Still going to sing the same song? Because either you're looking for 100+ fps to allow yourself to "enjoy" Witcher 3, or you're exaggerating, just like the other guy.
Keysplayr
21,209
50
What do you mean? The GTX970 is a powerful card. A great card. There is absolutely no disservice whatsoever recommending one of them. Kepler is receiving performance improving drivers. One was just released. Nvidia surely have been more focused on Maxwell, but a new driver release means they aren't done with Kepler. And how long ago was Kepler released?
Also, today, everyone knows or will be told, at least in this forum, what the 970 actually has under the hood. Like we just did. 970 is a great card and unless you play BF4 cranked at 4K, you won't go over 3.5GB very often, if ever. Do you disagree?
Status
