czar, if the G450 has the same theoretical bandwidth as the G400, then perhaps it does have a 64-bit memory bus, while using 64-bit memory chips. I wasn't aware of that because I have been out of the loop for about 2 months, haven't been reading up. Coupled with DDR-SDRAM, a 64-bit memory bus using DDR-SDRAM running at the same speed as a 128-bit memory bus using SDR-SDRAM would have the same theoretical bandwidth, all other things equal.
Of course, Matrox could also achieve the same effect by using a normal 128-bit bus for the G450 and simply cutting the bus speed by half(100MHz), but that's highly unlikely given current memory speeds.
In any case, the memory bus isn't a "dualbus". Only the internal core datapath uses a "dualbus".
