Originally posted by: RKS
I don't overclock. I would like something quiet and effective.
Originally posted by: toadeater
The 120mm rvt12025 has got to beat the AC Freezer. It's physically impossible for the AC Freezer to perform better, considering the size and design of both.
I wouldn't call Freezer 7 pro, at max RPM, quiet.
Push-pin type coolers are horrible!
You can use a backplate, from Thermalright, to turn any push-pin cooler to a backplate-mounted cooler for a reliable installation.
I disagree.
Find me a CPU cooler (i.e. a FAN) on HIGH RPM that's quiet. :roll: You can't; b/c ANY fan on "high" (2K rpm+) isn't quiet.
There is nothing inherently wrong with the push-pin mounting. I will admit this; after repeated mounting/unmounting the pins DO wear out. I'm experiencing that on my Freezer7 Pro now; however, it's been unmounted 6 times now. With careful mounting (ensuring the white pins go all the way thru the holes before pushing the black pins down) it still mounts securely.
I happen to dislike CPU HS's with backplates. Anything that is peel-n-stick is a one-time only use. Try and remove it and you are probably going to break either that backplate or the motherboard. :Q
For $25 and under you cannot do better than a Freezer7. Are there better HSFs? Yes, there are better ones. Tuniq Tower, that giant Thermalright (XP-90? IIRC?), etc. But they are twice the price.
The OP stated "I don't overclock." That nails it right there. F7 Pro FTW!!!!!
Cooler Master Hyper TX 2Originally posted by: MichaelD
Or you can install the backplate without sticking it to the motherboard. There is a peel-off strip that covers the adhesive. You can peel it off and stick it to the motherboard (poor choice). Or, you can leave the peel-off strip on it and install it just like that. Then, you can install and remove as many times as you want.I happen to dislike CPU HS's with backplates. Anything that is peel-n-stick is a one-time only use.
Fixed.For $25 and under I cannot do better than a Freezer7.
I didn't realize specs were vital to find a cheap HSFbut anyway:
Intel Bad Axe 2
E2140 that idles around 30C
4 HDDs
eVGA 7800GT
Antec P180
2 YLs in front of both HDD cages contolled by a Sunbeam Rheobus (the top and rear tri-cools are on low and bottom chamber fan has been removed).
all stuffed under a desk.
I do some moderate gaming but for the most part I have a few Pixar films on constant loop so I can watch football on tv.
Originally posted by: CallMeJoe
The RVT-12025 is also significantly larger than the AC Freezer, which could rule it out for many.
Intel Bad Axe 2
4 HDDs
eVGA 7800GT
Antec P180
Rate these things in order of importance:
Silence
Performance
Price
My pappy always used to says, things come good, cheap or fast, pick the two ya want cause ya aints getting all three. Anything thats fast and cheap aint no good, things thats good and cheap aint gonna come fast and things thats good and fast taint gonna be cheap!
and thats my motto.
The thinness is one of things that got me interested in it. Along with the $30 price.It seems to me to be the cooler to finally dethrone the AC Freezer for price-performance. Just wondering about how loud the fan is. The 92mm Vendetta beats the Freezer and TX2 by a couple of degrees, but it's very loud.
Originally posted by: Jhhnn
If price is the primary consideration, then this might be what you want-
http://www.newegg.com/Product/...x?Item=N82E16835186009
Your proc is rated at 65W- that's full bore, both cores running all out. Which means that the fan won't rev up except when really running it hard. Even at that, it's just a low hum, not really objectionable, at all. The fan is rubber mounted to the frame, and has fluid dynamic bearings for long life and no bearing noise at all.
These come with a bolt thru backplate, a good thing on intel boards, and they're actually easy to install, once you figure it out. Take the lower plastic holder off the sink, install it and the backplate onto the mobo, then screw the sink/fan assy onto that- just use some common sense when tightening down the screws- go back and forth until they're pretty snug.
Your really want a backplate on the board with any of the larger heatpipe coolers, so take that into consideration when making up your mind- you'll pay extra to get it with many coolers...
Intel Bad Axe 2
4 HDDs
eVGA 7800GT
Antec P180
Silence
Performance
Price
and thats my motto.
Price
Perfomance
Silence
I have the Intel OEM so obviously I still want something that performs or I would have stayed with the free HSF.
Originally posted by: elmatador
Hello!Anyone here got a socket 775 Freezer 7 Pro cpu cooler. If so, I was just wondering how fast it spins at full CPU load. According to the website the rated fan speed is 900 - 2500 RPM (PWM). Yet mine never goes above 1400rpm even under full load. I use speedfan and Everest to monitor fan speeds. Don't know how accurate they are. I've recently OC my E6300 CPU to 2450mhz with temps at 56-58 under full CPU load. Is there any way to make the fan spin faster to bring down the temps. Also out of curiosity, what's everyone else's temps. Thanks!
http://www.arctic-cooling.com/...hp?idx=79&data=2&disc=
http://www.svc.com/rr-cch-l9u1-gp.html
Much easier to lap compared to Freezer pro 7.
The fan is absolutely quiet even at max RPM (12V) unlike Freezer.
