is the Antec True 380S ATX Power Supply enough to run my setup?
imported_griegomas
its the one that comes in the older sonata's, the stats on the antec are at the bottom of this link
ill be using:
abit kv8 pro
athlon 64 3000+ with standard cooling
bfg 6800 ultra oc
2 512 meg dimms of pc3200 pqi ram
seagate 160 gb 7200 rpm drive
maxtor 60 gb 7200 rpm drive
couple of 80mm fans
will the antec be enough? or should i be preparing to buy a new psu? thanks in advance.
I agree, it's probably enough. I'm running a 3400+, X800 Pro, a whole slew of HDs and other equipment just fine on that PS.
You should be alright, but many people recommend that you atleast have 24A on your +12V for an overclocking A64 rig
Personally I would be a little weary of putting an Ultra on a PSU with only 18A@+12V. The ultras require 2 power connectors and can really use some juice when playing games. If you have any video problems, that would be the first thing to check.
