Is SSD speed related to how full they are?
Caveman
2,537
34
These are the drives I currently have:
Crucial M500 960GBCrucial MX200 500GB
I've been very happy with them. At what capacity can I expect them to slow down, and how quickly will that degradation be once they do?
Jembo
174
I believe as long as you keep minimum 7% free you won't have speed issues. Just partition off 7-12% & don't worry about it.
Charlie98
6,298
64
For giggles, I loaded my old 60GB Agility3 (SATA3) drive up to and beyond 80%, just to see, it started to affect it at about 75%, and very much so at 80%+... but that was a smaller drive, of course. 10% is probably a good figure, although personally I leave 20%, moving files if I need to.
Be glad you have a 1TB M500... my 120GB M500 is a DOG. I initially thought something was wrong... but, in my case, that's how slow the 120GB M500 is! I've got it in my HTPC where it doesn't really matter.
mv2devnull
1,526
160
What are you actually measuring? A full filesystem (depends on filesystem and operations) can be slow too.
Deders
2,401
It used to be for certain drives. Some would have 2 modes and the slower mode would activate when the drive was 50% full. I don't think it affects modern drives.
JimmiG
2,024
112
My 120GB Agility 3 is 95% full. However it's only used for games, so there are rarely any writes except when a game is updating. So it depends on how you use it too. An OS drive will get a lot more random writes.
It also depends on the drive, and newer drives/controllers are probably better at managing nearly full drives. They also have over-provisioning, SLC caches etc., areas that are not accessible in Windows. For example a 960GB drive might have 1024GB of raw capacity.
Cerb
17,484
33
86
Depends on how you use them. Even into over 90% used, they can maintain plenty of speed, for light use, and random access. FI, my 480GB one benchmarks fine, even when over 90% full. But, it slows down to ~50MBps sequential if I do something like copy some big ISOs to it, while it is nearly full. For normal use, it's fine even as it fills up, write amplification just gets a bit higher. But, for writing many GBs of sequential data to it, 100-150GB or so free seems to be the range where my 480GB starts really slowing down.
BarkingGhostar
8,410
1,617
You guys are in need of some Snakeoil Electricity to get them SSDz running right. Just like the Mobilz 1 oil in my truck, Snakeoil Electricity will do you right.
