Is Propel Zero going to kill me?
Rage187
14,276
4
I noticed they switched from sugar with a little sucralose to nothing but Sucralose in Propel Zero. I got concerned about it being an artificial sweetener so I looked it up on wiki and found the following:
According to the Canadian Diabetes Association, the amount of sucralose that can be consumed on a daily basis over a person’s lifetime without any adverse effects is 9mg/kg/day.
I then went to check out Pepsi's site and found that there are 46mg per bottle. I drink 3 bottles a day. Am I missing something? I'm drinking 15 times the recommended limit? Or is it 9mg per each kilogram of your weight per day?
http://www.pepsicobeveragefacts.com/infobycategory.php?pc=brand.1052.1000&t=1026&s=16.9&i=ntrtn
Kaervak
8,460
It's 9Mg per Kg of your body weight. You're fine. The only way it would be problematic is if you weighed 15Kg.
gorcorps
aka Brandon
Jul 18, 2004
30,741
456
I was just going to say... it says mg/kg/day
I'm assuming that kg means your body weight.
Rage187
14,276
4
Ok, that's what I thought. I've just never read a label like that in kilos or lbs.
I'm good for 706mg.
Locut0s
22,205
44
LOL yes it's per kg of your body.
BTW what did you think the /kg stood for? :hmm:
Locut0s
22,205
44
I live in the US, so nothing...
Umm it has nothing to do with where you live. If it had said 9oz/lb/day what would you have thought the /lb meant. Again I'm not making fun of your just curious what you thought it meant.
Rage187
14,276
4
I would have figured it out a little quicker. Why not just say per instead of /?
SP33Demon
27,928
143
Just drink Stevia, it's natural. Lifewater ftmfw. Oh, and Vitamin Water Zero w/ Stevia.
brblx
5,499
no reason to mock the guy for not recognizing the unit of measure.
'sposed to be mocking him for drinking diet flavored water.
Matthiasa
5,755
23
And this is why we need to improve our education system...
Can't have good little consumerists not understanding what they want.
lxskllr
60,922
11,254
Those sweet waters suck. Thin sweetness, and thin flavor. You want good water? Get some extracts from the spice section. I've tried lemon, anis, and peppermint so far, and they've all been great. ~1/4tsp per 500ml gives it a good flavor, with no sugar. It's cheap as shit, and better than most drinks you can buy.
IcePickFreak
2,428
9
You should be drinking Brawndo, it's got electrolytes!
Deeko
30,213
12
You'll be fine, some people get worked up over sugar replacements, but meh...its better for you than sugar.
Matthiasa
5,755
23
Not always, using artificial sweeteners can mess up how your body perceives a proper intake of sugar.
If one is use to just having artificial sweeteners if they were to start adding in actually sugar they are more likely to consume to much.
