- Jan 21, 2005
- 12
- 0
- 0
I just bought the following CPU/motherboard combo from Monarch Computers:
Shin-Etsu G675 Thermal Grease
MSI K8N Neo2 Platinum official V1.4bios
Athlon 64 3500 90nm at 220x11, 1.4Vcore (MBM5 reports 1.36V)
Thermaltake AMD K8 Venus 7+
The whole package came assembled so I just installed it into my case. Given their reputation, I figured they should have done the installation properly. The rest of the components are:
PDP PC3200-XBL (TCCD based) 2x512 memory from newegg
leadtek nvidia 6800GT AGP at stock speed (350/1000)
an older hauppauge bt878 based tv tuner card
Creative labs soundblaster live gamer
The setup runs well and very stable, and CPUID-Z shows it as a 90nm CPU. However I am concerned about the CPU temp according to MBM5. It's 40-45C idle, 55-58C in prime95. The case temperature is always around 40C and I leave the cover off. The articles on the web, with the exception of xbitlabs, all seem to place the temp of 90nm winchesters lower than that
hothardware 37 idle, 46 load
sharkyextreme 36.5 idle, 44.5 load
xbitlabs 39 idle, 55 load
So what could be going on? Should I upgrade my cooling? or maybe wrong reading from the motherboard? or could it something weird with the CPU?
Finally, the speed of the fan currently seem to change according to the case temp and not the cpu temp. Is this normal?
