Hi,
My CPU temperature idles at 45oC and loads at 52oC (using 2 instances of Prime95) or 55oC (using S&M). It also says my motherboard temperature (using a passive heatpipe solution) is around 49oC. I am wondering if these temperatures are normal for my system configuration listed below:
AMD Athlon 64 X2 3800+ o/c to 2.4GHz @ 1.45V
Arctic Cooling Freezer 64 Pro
ASUS A8N32-SLi Motherboard
2GB OCZ EL Platinum RAM
2X eVGA 7800GT o/c 470/1100 in SLi
Thanks.
Thanks.
