I was playing around with this "Pc Wizard" software and I noticed it said my "initial frequency" on my processor was 1.666 Ghz, but it says I'm only running at 1.261Ghz.
Does this mean my system is underclocked?
I've downloaded the "ClockGen" software from the same site, but I made no changes yet.
Is my system underclocked? Can I move it up to 1.666 or perhaps further? How far can it go?
My system is as followed:
CPU-Z Report
CPU-Z version 1.30.
CPU(s)
Number of CPUs 1
Name AMD Athlon XP
Code Name Thorton
Specification AMD Athlon(tm) Processor
Family / Model / Stepping 6 A 0
Extended Family / Model 7 A
Package Socket A
Technology 0.13 µ
Supported Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE
CPU Clock Speed 1261.2 MHz
Clock multiplier x 12.5
Front Side Bus Frequency 100.9 MHz
Bus Speed 201.8 MHz
L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L2 Cache 256 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed 1261.2 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 64 bits
Mainboard and chipset
Motherboard manufacturer ECS
Motherboard model K7S5A,
BIOS vendor American Megatrends Inc.
BIOS revision 07.00T
BIOS release date 04/02/01
Chipset SiS 735 rev. 01
Southbridge SiS ID0008 rev. 00
Sensor chip IT 0
Graphic Interface AGP
AGP Status enabled, rev. 2.0
AGP Data Transfer Rate 4x
AGP Max Rate 4x
AGP Side Band Addressing supported, not enabled
AGP Aperture Size 64 MBytes
Memory
DRAM Type DDR-SDRAM
DRAM Size 128 MBytes
CAS# Latency 2.5 clocks
RAS# to CAS# 3 clocks
RAS# Precharge 4 clocks
Cycle Time (TRAS) 6 clocks
Bank Cycle Time (TRC) 10 clocks
# of memory modules 1
Module 0 Hitashi DDR-SDRAM PC2100 - 128 MBytes
CPU-Z Report
CPU-Z version 1.30.
CPU(s)
Number of CPUs 1
Name AMD Athlon XP
Code Name Thorton
Package Socket A
Technology 0.13 µ
Bus Speed 201.8 MHz
L2 Location On Chip
Sensor chip IT 0
AGP Max Rate 4x
Memory
DRAM Type DDR-SDRAM
