Just put this thing together yesterday. Complete system:
Asus A7N8X Deluxe 2.0
512MB Mushkin PC3200 (Basic stuff)
AMD Athlon XP 2500+ w/ stock HSF
Antec SLK3700AMB with stock 350W ps
Vantec Stealth 120mm fan intake front, stock Antec 120mm fan outtake rear
Radeon 9700 Pro
2x Seagate 120GB HD
Pioneer A06
Toshiba DVD-ROM
floppy
After some good amount of testing I can get everything to go stable at 166FSB. Gave it up to 1.75V at 200FSB and it won't go stable. Now, I have it at 11.5X and 180FSB, and prime95 likes it ok. I finally had the sense to put both hard drives in the bottom two spaces and to rearrange my cables to maximize the air flow. NOW afterwards it finally runs at 56 degrees C at this 180FSB 11.5X (2070Mhz) at 1.725Volts with case temp of 32 degrees C under load. I know this is probably high for most of the overclockers here so any suggestions are greatly appreciated. I would really like to run at at least 400FSB at this temperature, or of course lower.
I think possibly my limiting factor may be the northbridge heatsink. Right now at 56C the CPU HSF is somewhat hot to the touch. However, the northbridge heatsink is much, much hotter. Not too hot to the touch, but almost so. Anyone know of a good way to cool this thing down? There doesn't seem to be any easy way to get a fan blowing on the northbridge heatsink, so anyone else had to struggle with this with this MB/case? I would also consider other HSF's for the CPU, but right now I don't think that it is totally my limiting factor. Any help greatly appreciated!
Radeon 9700 Pro
2x Seagate 120GB HD
Pioneer A06
Toshiba DVD-ROM
floppy
