My sony monitor has been deteriorating in quality for months, by the time i realized it the warrenty was already up. Now it has gotten so bad that when i have no background, and it is set to all black, i can see 10 almost horizontal lines across the screen. This is not related to the 3 stabalizer lines that you see on all sony monitors. I am wondering if this is just gonna keep getting worse. It started by the brightness going, i had to lower the brightness to look "normal" every 2 months, eventually it wouldnt go any lower, now it is starting to affect the quality of the images. Need to replace the monitor, do they all die like this eventually? By the way is there a better monitor out now ? I have a sony Multiscan E400. It is a 19 inch monitor. I want a sony tube, 19 inch but the original monitor i wanted was a .22 grill, but sony discontinued it and there was at the time no comparable 19 inch to the 21 inch F520.
Any suggestions one which 19 inch monitor has the best picture? I loved this monitor until it started to die.
Thanks,
Lou
Thanks,
Lou
