Is my PSU unit poweful enough?
runzwithsizorz
I have Seasonic x650 Gold 😕
Gaming at 1080p (Skyrim, Witcher 3 when it arrives)
Currently have MSI hawk 7870
Considering buying either : GTX 970 or R9 290
Will not be buying until I see "real" tech specs for Witcher 3 (after it's released)
Just worried about the PSU power. I only use one vid card.
Thanks,
The Wife
Thanks,
The Wife
You'll be fine. Seasonic is a very reputable PSU manufacturer; you can trust their units to consistently output the specified amount. I looked up the maximum power usage for a third-party, factory-overclocked R9 290X (which is about the most power-hungry single GPU card on the market today). TechPowerUp measured it at 316W. This is with Furmark; a normal game would use far less power (they found a peak of 253W and an average of 221W on Crysis 2). So, even if we go with the worst-case scenario to be on the safe side, that gives a power budget of 330W left over for the rest of the system. That's more than enough.
