Vehicle: 2004 Pontiac Grand Prix GT2
Miles: 141,000
Service: Regular maintenance, full tune up at 80K (w trans flush), trans drain/filter replaced (not full flush) at 130,000
EDIT: No check engine light, no other problems.
I have two very intermittent problems:
1. From a full stop, slams into gear. Once in a while at a stop light, when I press the gas, the car hesitates for a moment and then slams into gear. The entire car jolts very hard. This happens maybe a couple times a week at worst (or not at all for weeks). When it first started it would happen like once every 3 months or so. This jolt does not happen in any other gear, only when starting from a full stop - car will usually shift smoothly otherwise.
2. On occasion after smooth shifts while driving around town, the car will suddenly start shifting roughly. It is like a jerky/bump sort of feel at every gear shift. When this occurs it will do it at every gear, and it will continue until the car is turned off. I noticed that if I stop and put the car in park, then go again - the problem will persist. However, if I turn the car off, even for 5 seconds, then restart and drive, it will shift smoothly again.
There seems to be no trend as far as is the car being cold or hot, etc. Both problems seem completely random. The fact that it is so intermittent, and turning off the car seems to stop the problem for a while makes me wonder if it isn't some kind of computer timing issue or something.
I've hear horror stories about some of our local trans shops saying a rebuild/replacement is the only solution when a $300 fix could solve the problem - so was just hoping for any input before I take it in. Thanks for any advice you can offer!
Miles: 141,000
