ExcaliburDragon
Sorta been pulling my hair out on this one lately.
My machine:
Intel P4c 3.2GHz (stock speed)
Albatron PX865PE ProII Motherboard (1.10 BIOS, onboard LAN)
4x Corsair CMX512-3200LLPT (basically 2x TWINX packs), total of 2GB RAM
HIS Excalibur X800 Pro IceQ II (stock speed)
2x Maxtor 120GB IDE drives (7200rpm)
1x Maxtor 80GB IDE drive (7200rpm)
Sony DVD/CD-RW/+RW combo drive
Sound Blaster Audigy 2 ZS Platinum (w/front panel)
Leadtek TV PCI card
3x case fans
Front panel (w/blue leds) fan control
Floppy drive
Antec TrueBlue 480 PSU
Basically, my machine is not very stable in this configuration. Sometimes it'll just lockup (usually in 3D gaming sessions). Sometimes it'll reboot. Sometimes the signal to my monitor drops (and the machine still appears to be on/running, but not responsive). Maybe an app will crash with seemingly randomish error messages. In other words, nothing easily reproducible, every time.
The X800 Pro & the second GB of RAM are recent additions to the machine. If I put in an older video board (GeForce 5900 FX), the system is still slightly unstable, but not so much with the monitor signal dropping, or outright lockups in 3D games.
If I remove the extra GB of RAM (leaving 2 RAM modules in place), the instabilities seem to go away, for the most part.
I ran Memtest86 3.1 on the RAM and when I have all 2GB in place, I get a small handful of Test #4 errors. If just use 1GB, I get no errors. If I test each module alone (512MB at a time), I get no errors on any module. (with 2GB installed, I used the -most- relaxed memory timings possible in the BIOS, which seems to diminish some of the more obvious problems, but the RAM still generates errors when tested)
Corsair is of the opinion that it's a power issue (claiming that using all four modules consumes a large amount of power; also claiming that the Antec PSUs are 'known to be problematical') and that my power supply isn't up to snuff for the job. Everything I've read about the Antec series of PSUs seems to indicate otherwise, but I don't have enough information about the very specific power needs for each component, and on what rail, to see that problem in the numbers.
With the video board (new, powerful board) and a lot of RAM, I would agree that it sounds like a possibility... but it's already a darned good PSU.
My machine is moderately populated with stuff, true. But is it likely that it's populated enough that the Antec 480 isn't quite good enough to manage it? Maybe too light on the +12V rail, for example? When the machine had 1GB & the GeForce in it, I had cause, every once in a while, to suspect that possibly the video board wasn't getting the power it wanted (it, too, has a seperate molex connector on it, like the X800 Pro does). But the machine wasn't generally unstable. Only every once in a while something funky would happen, usually when really taxing the machine.
I know that the X800 Pro is likely to need more power, especially when 3D gaming at high resolutions and such, and that's usually when the machine would start acting up - again, sounds rather like a power issue. But it's darned hard to prove without having an easy supply of bigger/betters PSUs on-hand to check.
Thoughts? Thanks. 🙂
My machine:
Leadtek TV PCI card
3x case fans
Floppy drive
Thoughts? Thanks. 🙂
