JimKiler
I have the following parts:
PCPartPicker Part List: https://pcpartpicker.com/list/3jTKBZ
I recently upgraded my main PC to Ryzen 3800X and the above is now my secondary rig. My secondary PC previously had an Althon X4 on AM2 mobo and worked with the above power supply and an entry level GPU. Now that i put this secondary PC together it turns on and the boot up LED's are fine but i get reboots constantly. If I touch the case it reboots. If I put in a USB drive it reboots, if I touch the Cat6 cable it reboots. I disconnected the GPU and all the case fans and still it reboots. Funny enough even though win10 went from AMD to Intel the OS still boots.
Any suggestions or is it time to buy a new PSU? if everything is unplugged the PSU should work right? Being my secondary PC the PSU never got a lot of use despite being old i would not consider this PSU older than 3 years. I would try using my main PC PSU but if I am going to go thru the hassle i will just buy a new one.
In other words i swapped out the Mobo, CPU, and RAM to make the above build and now it does not stay on without rebooting. This mobo, CPU, and RAM worked in my other build just fine. Did i short circuit the mobo or is my PSU underpowered for this build?
- CPU: Intel Core i7-4790K 4 GHz Quad-Core Processor ($470.80 @ OutletPC)
- CPU Cooler: be quiet! Pure Rock Slim 35.14 CFM CPU Cooler ($28.00 @ Amazon)
- Motherboard: Asus Z97-AR ATX LGA1150 Motherboard
- Memory: G.Skill Sniper Gaming Series 16 GB (2 x 8 GB) DDR3-1866 Memory ($97.99 @ Amazon)
- Video Card: MSI Radeon R9 270 2 GB TWIN FROZR Video Card
- Case: Antec Three Hundred Two ATX Mid Tower Case ($89.99 @ Amazon)
- Power Supply: Corsair Builder 400 W 80+ Certified ATX Power Supply
- Optical Drive: Asus BW-12B1ST/BLK/G/AS Blu-Ray/DVD/CD Writer ($109.88 @ OutletPC)
- Case Fan: Cooler Master SickleFlow (Red) 69.69 CFM 120 mm Fan ($9.39 @ OutletPC)
- Case Fan: Cooler Master SickleFlow (Blue) 69 CFM 120 mm Fan ($9.39 @ OutletPC)
