Is my power supply enough?
Acoshi
I seem to have problems powering up my system. Today it took me a half hour to turn on my computer. I turned it on and everything was working but nothing came up on the screen.
I was wondering if it is my power supply, do you think that its enough or should I get a new power supply?
[my specs are below]
I have and it still takes a bunch of times to restart. I have done everything except swap the power supply or CPU or motherboard.
I have the same PSU powering my system and it is great. Voltages are all at spec. And I do believe that my system is a bigger power hog than yours (OP). Now it's true that your power supply may be dying, but if it's not is has enough power for your rig.
uninstall somethings that you have recently installed, this could be the cause of the slow down. and if you recently installed sp2 this could be a cause also.
