- Oct 17, 2001
- 542
- 0
- 71
I have an Antec Aria SFF I use for Home Theater use and also to rip/encode DVDs.
It has a proprietary Antec 300watt power supply [can not be swapped out for bigger or different one]
SYSTEM SPECS:
Intel Springdale 865 mATX board
2X512mb PC 3200 memory in Dual Channel
Current CPU is a 2.8C Northwood
Radeon 9600 Pro AIW
Hercules 7.1 sound card
250gb WD SATA HDD
Firewire card
Plextor 740A DVDR
It runs fine with the 2.8C in. No heat issues or anything.
I have options to put in a 3.4E Prescott or a 3.2C Northwood. I want more speed to encode DVDs.
Is this 300watt power supply big enough to run a 3.4E or 3.2C?
Thanks for the help
P.S. Forgot to add NO OVERCLOCKING
SYSTEM SPECS:
Radeon 9600 Pro AIW
250gb WD SATA HDD
Firewire card
Plextor 740A DVDR
Thanks for the help
