When I was using my machine yesterday it just went dead and now I can't turn it on. When I press the power button there is no sign of life at all (no fans, leds etc.). Everything is off. I suspected a dead power supply and borrowed my friend's (known good) Antec 550W. When I connected this to the computer and pressed the power button the processor fan ran for half a second and then turned off. If I press the power button again, nothing happens. If I disconnect the power supply from the system for a few seconds and then connect it again, the same thing happens when the power button is pressed (cpu-fan will run for half a second and then die again)
I have measured the output voltage in the molex connectors with a multimeter and when the power button is pressed the voltage level (as expected) rises at once, and then after the half second returns to zero again...
I have stripped the system completely (except for psu, cpu and motherboard) and no drives, cables or expansion cards were connected but still no sign of life or memory beeps. I have not tried to start the computer outside the case because I don't expect any short circuits (have not moved the computer recently) and don't believe that it would make any difference.
Question 1: Could the failing component be anything else than the motherboard?
Question 2: Could a failing processor cause this behaviour?
Question 3: Could this problem be caused by a corrupted CMOS-memory so resetting this might help?
