Is My i7 A Mutant or Am I Doing Something Wrong?
Scionix
248
Yes check your bios my P6T Deluxe V2 has an option disable cores.
Ru-ro. And I didn't kill them with the OC, it's had 2 cores the whole time (which I was curious about). I'll go mess with it. Pretty sure this is because I haven't updated BIOS yet, it has all cores enabled in the menu. Plus I got a 40k CPU score in 3dmark vantage, so I'm pretty sure all 4 cores are working.
EDIT: Taskmanager also shows 4 cores, and for the guy who asked, load temps never got over 60 degrees.
brandonwh64
1,543
yea heres a screeny of mine @ 4.1ghz this is what its suppose to look like
Maximilian
12,604
15
Shouldnt it show 8 since you have HT on?
Ben90
2,866
Just making sure, this is what taskmanager should look like. CPUZ can have a lot of issues, note multiplier in the following screenshot.
Scionix
248
Oh crap...
Task manager is only showing four of those columns (which I thought were cores).
Ugh, I want to update BIOS really badly now, but I don't trust the windows application thing ASUS uses. Stupid EZ Flash :(
But, I couldn't score 40k CPU score in 3dmark vantage without two cores, right? Right?! :(
How did you bring up that processor affinity window?
Ben90
2,866
Go to processes->right click any process->set affinity
What doesn't make sense though is that the p6t series only supports the i7 and Xeon equivalents so its not like your running some just released processor or anything.
Ive never updated a bios, but that is likely the problem so I would try that next. Goodluck :)
Scionix
248
Ok, I'm definitely concerned now...
Updated the BIOS, CPUz still showing 2 cores/4 threads, and task manager still showing only two cores. The only thing that seems to have more is device manager, which has 8 i7 920 icons. Any other ideas?
MrK6
4,458
4
Does it say the same at stock speeds? Did you install your motherboard chipset drivers?
Scionix
248
Ok guys, get ready to laugh at my expense.
Went into msconfig, unchecked the "boot with x cores" box, re-booted, and now everything is showing 4 cores/8 threads. Hurffffffffffffff.
I wonder if my 4GHz OC will still work on 1.25v? :D
EDIT: It does o_O
So back to the original line of questioning...
Is my i7 a mutant? :D
taltamir
13,576
is it STABLE @ 4ghz @ 4 cores @ 8 threads @ 1.25v @ what heatsink/fan/thermal paste?
Scionix
248
Again, I don't know if it's P95 stable yet, but it booted at 1.25v, which seems kind of crazy to me.
My watercooling loop is in my signature, but with a heatkiller 3.0 waterblock. Arctic Silver 5 Thermal paste.
aka1nas
4,335
That's not crazy at all with watercooling. Mine does 4.2 with high-end air (though I am at more like 1.35v).
readymix
357
EDIT: It does o_O
who does'nt love a happy ending while verifying man can be content on 2 cores.
and by the way my asus p6 autoed out at 1.41v/175bclk
CarpeDiem99
518
I'm wondering whether I should go for 4.5Ghz...
This is so much easier than my Q6600...
It is easier to OC than a Q6600, but 4.5 is very hard to get. First test your configuration with LinX and see if you are stable or not using maximum memory for the test. Then start working your way up.
Scionix
248
I was being a bit facetious, but yeah, I'm going to try and inch it up a tad. I would love a stable 4.2Ghz
faxon
2,109
Cmon you don't have far to go to join the 4.2GHz club now. Make sure you get the latest version of OCCT for your prime testing, it has linpack built in as well so you can use both
taltamir
13,576
OCCT FTW! its what i use now. it has GPU tests, PSU test, every type of measuring you could want, etc...
aigomorla
21,130
3,660
+/- .5 DRam vs Vcore rule!
Your @ .4 right now.
With Vdroop you will go past the .5!
Either Lower the ram, or UP your vcore unless you want to wear out that cpu faster then you should.
OP WTF happened to your 2 cores?
Id be worried if you cant get them back.
