Is my engine about to blow up?
Status
Not open for further replies.
SAWYER
16,742
42
2007 Pacifica
Since last year is has had a knocking in the engine. Today it died and when I started it(had to boost it) it is making a horrible sound like parts are just flying around but it will idle and drive. I parked it and haven't started it since. I don't have any oil leaking or a mess under my hood.
SparkyJJO
13,357
7
Usually it is a good idea to check out the knocking when it starts, not just keep driving it hoping that it will go away :p
twinrider1
4,096
64
You're fine. You just need to change your oil to this...
F17988973
Rifter
751
From what you describe it could be anything, spun main bearing, broken rocker arm, timing chain/belt issue, snapped con rod.
I would drain the oil and check for cunks of metal for a start and go from there.
SparkyJJO
13,357
7
Even on a Chrysler? Why?
The Pacifica isn't a bad vehicle at all. But unless the car is a $500 beater that you expect to blow up and don't care when it does, then yeah, check the problem before it becomes a really huge and expensive problem.
Status
