Is my cpu running to hot
lurchbourke
40
hello,
i'm using a
Thermalright SI-97A heatsink
Panaflo 92x25mm Medium Speed 1 8.45 8.45T fan
Arctic Silver 5 paste
on a athlon XP 3200+ socket A
with a
ASUS A7N8X-E Deluxe mobo
i'm getting a reading of 40C in the bios for the CPU temperature with Q fan control on full speed and the case is open at the moment. Should the temp be less or is this normal. i just got them it the first time i've used anything besides a stock fan/headsink, so i'm not sure. what is a safe temperature.
would i be able to think about overclocking. or should i make some changes to make it cooler
thanks for reading this
bdww00
Banned
Sep 6, 2005
740
omg dude 40 is semi low
my 3000 at idle w. stick hsf not oced is 42c so.....
i must put on thermal grease good
maybe put door on side of case
AliasX
508
I was averaging 31c idle, 42c load. Now its a little hotter, and im getting 37c idle, 48c load.
Howard
47,982
11
40 degrees is fine. See how far you can overclock before trying to lower the temps.
