- Oct 10, 2002
- 3,558
- 205
- 106
I have a 3 year old build with a 4790K, Asus Z97-AR mobo and i put a Be Quiet Pure Rock Slim cooler on it and I have 4 case fans in an old Antec 300 case. I am doing a couple handbrake encodes and my CPU is going to 68-70 degrees Celsius. I ran the Asus fan tuning app (i use standard option) i hear the fans ramping up but my fan thresholds seem like this CPU is running too hot. I am not overclocking although i did run the Asus app to attempt it and it wanted to run it at 4.6GHz but I reset that so i am back to stock settings.
Should i be worried? I read online that 72 degrees is the threshold i should stay under.
If I were to overclock what temp would i want to stay under if different than non overclocked.
I should add that i switched the fan setting to turbo and now my CPU temp is 68 degrees, should i be concerned?
