William Gaatjes
- May 11, 2008
- 20,138
- 1,149
- 126
The problem I have with the rejection of the young earth theory is that the measures used to measure the age of the earth could possibly be inaccurate.
I'm not saying that I agree with the young earth theory, but there has to be a higher power, although I think that higher power was good, since I'm a Deist and since I believe in the Laws of Nature and of Nature's God. That higher power could just be the universe, I don't know. However, if the universe is the higher power (the creator transformed themself into the universe, which is Pan-Deism), then abiogenesis would have to have occurred, and I don't understand how life could've come from non-life.
I can share this : Seek the explanation by traversing the internet for clues.
If you believe or not, the universe and what it is made of, has certain rules and behavior. Self assembly is the basis of life.
When you take a lot of separate atoms from the same element, these will combine into a certain lattice, a formation of atoms. When you use different kinds of atoms (meaning different elements) you will still get a lattice formation but of course with different properties. The real secret is that the environment is important. Meaning the temperature and the amount of EM radiation and the amount of trace particles (for example like cosmic rays). Atoms need to combine. That is what gravity is for. Electricity and magnetism is what is needed to set the behavior of the atoms and the sub particles these are made of. A lot of scientists are going to curse me, but i do not care for they are no different than the liars who preach for their own fortune.
The thing is, the whole connection from start of the universe universe to formation of life anywhere in the universe is layered. It is structured. Although what is happening in the universe can be perceived as chaotic, when using a macro view, the chaos is the driving force, it is the force behind creation on a smaller scale such as solar systems. But in reality, there is no chaos. For us humans it seems chaos because it is so hard to grasp and keep track of everything. If you try, you might end up finding the answer without being able to share it. It is best to to postpone such an inevitable event. ^_^.
Life did not start on the earth when there was a magnetic field to shield everything. It started when there was not a magnetic field to shield life as we have now. Life started on planets without a shield. The energetic solar wind is needed to jump start life. And life started in space in the comets traveling around the young sun. Eventually these comets crashed into the planets or into the sun itself(to bad
We humans need constant power because our bodies (body cells and bacteria) are buzzing with activity. When we could completely shut down that activity and lock the atoms in our body into a stable fixed position( not xyz, but in every way) , we would not age(truly not age). But that would be as for us to live in an energetic void. No temperature, no EM, no gravity ripples(modulation). Nothing to draw power from. In the end we would collapse.
Single celled organism come close to being able to completely shutdown and come to life when the environment is suitable. But even bacteria, cannot with stand an energetic void : 0K temperature, No EM, No gravity modulation. No virtual particles. Nothing. The perfect void. There have been tests done with bacteria and small creatures that are able to withstand pressures vacuums, radiation levels and temperatures that would destroy every complex man made device or structure ever build up to some time into the future.
For example the tardigrades.
These critters have very special features.
http://www.space.com/5817-creature-survives-naked-space.html
http://en.wikipedia.org/wiki/Tardigrade
These 8 legged little guys do look kind of cute.
The water bears, known formally as tardigrades, have an ability similar to brine shrimp (also known as Sea Monkeys), which are familiar to many children for their ability to come to life after being sent to homes by mail-order. Tardigrades are speck-sized things, less than 1.5 millimeters long. They live on wet lichens and mosses, but when their environment dries out, they just wait for a return of water. They also resist heat, cold and radiation.
The radiation resistance was most surprising to scientists.
The tardigrades were aboard the FOTON-M3 spacecraft launched by the European Space Agency (ESA) in September 2007 and were exposed to open space conditions, the scientists reported today. They were examined upon return to Earth.
Most survived exposure to the vacuum and cosmic rays, and some even survived the exposure to the deadly levels of solar UV radiation, which are more than 1,000 times higher than on the surface of the Earth.
The survivors "could reproduce fine after their space trip," according to a statement released today by Cell Press, the journal that published results of the test.
How the post-flight tardigrades could do it "remains a mystery," the researchers write.
When dehydrated, water bears enter into a dormant state in which the body contracts and metabolism ceases. In this death-like dormant state, water bears manage to maintain the structures in their cells until water is available and they can be active again.
UV rays consist of high-energy light particles that cause severe damage to living tissue, as is evident when you get a sunburn. But more so, they can also damage cells' genetic material, causing skin cancer, for example. The radiation, in wide-open space, also is thought to be sterilizing.
The work was led by K. Ingemar Jonsson of Kristianstad University in Sweden.
Jonsson suspects that even the water bears that got through the space trip without any trouble may in fact have incurred DNA damage, but that the animals managed to repair this damage. Figuring out how they did that could inform medical research.
Wiki quote :
Tardigrades are able to survive in extreme environments that would kill almost any other animal. Some can survive temperatures of close to absolute zero (−273 °C (−459 °F)),[6] temperatures as high as 151 °C (304 °F), 1,000 times more radiation than other animals,[7] and almost a decade without water.[8] In September 2007, tardigrades were taken into low Earth orbit on the FOTON-M3 mission and for 10 days were exposed to the vacuum of space. After they were returned to Earth, it was discovered that many of them survived and laid eggs that hatched normally.[9][10] In May 2011, studies involving tardigrades were included on STS-134, the final flight of Space Shuttle Endeavour.[11][12]
The scientology church are a bunch of crackpots. But if god is to be found anywhere, do not seek god on the earth or in space. If you need a god, then that god is everywhere around you. Show some love for all that you are and surrounds you. Instead of having faith. Faith is a path to get lost. Love is as the anchor to keep a ship at the desired location in violent water.
It works a whole lot better. Faith can be corrupted, love just is or is not.
