is lg optimus v better than samsung intercept on virgin
gsaldivar
8,691
Yes, if you don't need a keyboard the LG Optimus is definitely better. The clock speed on the Optimus CPU is slower but is coupled with twice the RAM for overall better performance than the Intercept.
Samsung Intercept:
800MHz ARM6 (?) family CPU, 256MB RAM, EVDO Rev. 0, Android 2.1 (2.2 update promised)
LG Optimus V:
600Mhz ARM11 family CPU, 512MB RAM, EVDO Rev. A, Android 2.2
Puddle Jumper
2,835
Yes, if you don't need a keyboard the LG Optimus is definitely better. The clock speed on the Optimus CPU is slower but the processor is newer, coupled with twice the RAM for overall better performance than the Intercept.
Samsung Intercept:
800MHz ARM6 family CPU, 256MB RAM, EVDO Rev. 0, Android 2.1 (2.2 update promised)
LG Optimus V:
Actually the Intercept has the better cpu, they are both ARM11's but it's clocked higher. The extra ram on the Optimus probably makes up for it though and it does have Froyo.
gsaldivar
8,691
I changed my comment above but there are many sites that list the Intercept CPU as ARM6:
http://www.mobiletechreview.com/phones/Samsung-Intercept.htm
Performance: 800 MHz Samsung S3CC6410 CPU (ARM6 family) with Qualcomm QSC6075 processor. 256 MB built-in RAM. 512 megs internal flash storage.
OBLAMA2009
6,574
does optimus have evdo rev a amd the intercept have rev 0 and does this make optimus 3g much faster or not?
