Is it worth upgrading to Kit Kat ?
Eug
23,790
1,361
Yeah, I think most of us complaining about Kit Kat on the Nexus 7 have the 2012 model.
I suspect it may be memory, because the 2012 has only 1 GB RAM, whereas the 2013 has 2 GB. 2 GB seems to be the sweet spot for Android. It could also be the CPU though.
I don't know what hardware the 2103 model has.
sweenish
3,656
60
Those complaining about the dialer could just get a new dialer. It's a replaceable part of the OS.
https://play.google.com/store/apps/details?id=com.contapps.android.dialer
There's one example.
Part of it is the amount of memory, the bulk of the issue is the memory bandwidth and how it basically doesn't exist in the 2012 model.
kmmatney
4,363
Well - my LG Optimus Pro G on KitKat is behaving a lot better after a factory reset. Before the factory reset the phone was constantly warm and chewing up battery after the KitKat upgrade. I followed the instructions and cleared all caches, but apparently that was not enough. Now I'm finally a happy camper.
MrSquished
22,939
21,051
And being able to use ART.
I found the KitKat dialer a big improvement over jelly bean's as it finally supports T9 contact lookup from the numeric pad - i.e. type a couple of letters of a name, and a list of possible contacts appear. Sense and Touchwiz were doing this back in the days of gingerbread, so I've no idea why it took so long.
agreed. i like the kitkat dialer so much i finally stopped using DW Dialer and Contacts premium app after using it for the last 2-3 years exclusively.
Raduque
13,140
138
4.4 changes the way the SD cards work, making them more secure if slightly more annoying to use. Not a good enough reason to avoid the update, IMO.
It's not doing it to make it more secure, it's a stepping-stone towards remove support entirely, IMO.
You can get an sdfix app from the Play Store (unless Google has decided to remove it) that uses root to undo Google's breakage of the SD card.
Red Storm
14,233
234
Why then did all the major flagships have an mSD slot, which was not the case the year before? The security changes were needed and are welcome.
